Will someone please post an Article for me?
Riceras
Will someone please Post how to change the Gauge Cluster on an EK?
Ive looked and there arnt really any instructions!!!
I've done it before its not hard at all.
- There are 2 black screw holding the bezel on so remove them
- This is the hard part, drop the steering column all the way down, and pull
the bezel straight out; I broke my clips when i removed mine so be
careful. The clips are on the lower part of the bezel one on each corner.
- With the bezel removed you can now access the cluster; there are 4-6
more black screws to remove. Once those are out carefully pull it out
like 2-4inches.
- That will give you enough space to reach behind and unplug all of the
connections.
Finto
