will this engine(swap) work......
Discussion in 'Civic and del Sol - EG and EK' started by civicdude007, Jul 18, 2008.
  1. civicdude007
    civicdude007 New Member
    Dublin, Va
    i am pulling my 1'5l out of my 95 civic and looking for a replacement.i found a d16z6 and it is a single cam vtec engine. the engine was pulled out orinally from a 95 civic . what else do i need to get my civic back on the streets.......is the harness the same , tranny bolt up ...is there anything else i need to purchase?
  2. mintoxik
    mintoxik Member
    Oceanside
    if i've read enough on here ya it will work you will need a new ecu and wire up vtec,and new motor mounts. the tranny i dont know about, but i would get the z6 tranny anyway if your going to swap the hole motor
  3. civicdude007
    Dublin, Va
    so if i get a harness from a vtec d16 and a computer from the same d16 vtec engine that will be it..........?
  4. stevennn09
    stevennn09 Member
    Ohio
    :werd:
    only thing. the tranny will fit. but if you can you might as well upgrade as long as it's the same as in auto or standard as the current one. if not it might be hard to convert for someone with not alot of knoweldge. i have a z6 in my car and i actually have grown to like it quite a bit.
  5. stevennn09
    stevennn09 Member
    Ohio
    i think you can mod the harness to work 4 vtec. i might be wrong though
  6. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    if you are getting the engine wiring harness from the D16Z6 engine, everything will plug into your original wiring including the ECU.
    some the plugs are tricky to remove but if you take them off the mounts and pull on both sides it helps.
  7. delsol88
    delsol88 Blinker Fluid Specialist
    JC,MO
    u can use old mounts in the original car. advice on the tranny, assuming both are manuals, if u want better mpg stick with the 1.5 tranny longer gears so you will get better mileage.
  8. mintoxik
    mintoxik Member
    Oceanside
    but if not then just wire up vtec its not that hard
  9. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    All you have to do is either a)run the two wires from your solenoid to your ECU or b) go to www.rywire.com and buy the VTEC wiring harness.
