Windows in doors need fixed
rpmison
windows vibrate and the noise is killing me.is there a gasket that I can get to fix it? It's a 1992 coupe
when you shut the doors do you hear stuff rattling aroundin the door? if so its your window guide they prolly came loose
hey thanks for the tip.I know it sounds like the glass is going to break if the windows are down at all.Do you know if its a easy fix or not?
Not really that hard to do, just be super gentle when your popping the panels off the doors, and try your best not to tear the plastic waterproofing behind the panel. Otherwise all the bolts in there are fairly easy to get to, and the loose one(s) should be obvious.
