jdm_cracker
this is for an ek civic .... the wipers worked when you you turned them on but when you switched them to off they'd stay on... so i pulled the switch out and did a diagnostic check as outlined in the maintenance manual ... switch was fine ... put it back on ... now the wipers worked in every position except int. where they got up stay up for a while then come halfway downstop and then come all the way down... i was gonna do the test on the wiper relay but there's an srs harness plugged into it, i was afraid of deploying the airbags so i left it... what do u guys think it is ... anyone ever come across this??? what should i do??
