Wire for Trunk
Anyone know which and where the wire for the trunk is? Noticed that my alarm isnt triggered when you pop the trunk. 92 Civic. Thanks.
hope this helps
12volts white + brn conn abv fusebox
Starter black/white + brn conn abv fusebox
Ignition black/yellow + brn conn abv fusebox
Power Lock green/white - in drivers door
Notes: Door lock module in door above the speaker. the wires can also be foundat the anti-theft if equiped.
Power Unlock green/red - in drivers door
Notes: Door lock module in door above the speaker. the wires can also be found at the anti-theft if equiped.
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ red/black grn plug top of f-box
Parking Lights- white/black anti-theft module
Notes: the anti-theft module is located under the drivers seat. only some models are equiped with anti-theft.
Hazards
Turn Signal(L)
Turn Signal®
Door Trigger lt green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer blue AC 2-pin plug near distr.
Notes: Also at round gray connector next to hood strut.
Horn Trigger blue/green - steering column
Notes: can also be found blue/red at anti-theft if equiped
Memory Seat 1
Memory Seat 2
Memory Seat 3
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox, under dash
this is the wire for the trunk pin if this doesnt work then you need a new pin switch
