Wireing harness 89 HF
Discussion in 'HYBRID -> ED-EF / DA' started by ko_si, Aug 11, 2005.
  1. ko_si
    ko_si Junior Member
    ok guys ive done my search on the site. ive been here a while and most of the time im able to find my answer simply by using the search button. but this time i wasnt so lucky. heres my question.
    i have a 89 crx HF, which will be getting a b18 from a 98 gsr swaped into it. the engine has the stock harness. my crx is obd0. i have a obd0 to obd1 conversion harness that comes pre-wired for vtec, and also for a obd1 or 2 distributor. the question is can i do away with the stock GSR harness, and use the one from the HF, then wire my vtec, and the dirtibutor, with the conversion harness? and one more thing will i need a different distributor??
  2. drpenguin
    drpenguin Senior Member
    Salem, Or
    should work
  3. DirtyRice
    DirtyRice Junior Member
    your stock harness will work you will just need to convert you car to mpfi and mod your harness to a mpfi setup. u need a obd0 b16 distributor or a hacked up 90-91 integra distributor.
    thats all folks!
    -DirtyRice-
    !!!Got to my website and get my newest album free!!!
    [​IMG] [​IMG]
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    holy gihugic sig batman
  5. ko_si
    ko_si Junior Member
