Being that there is no obd0 GSR and your car is obd0 you will need to do an obd conversion on either the car or motor.
If your going to stay obd0 you need a obd0 dizzy,injectors with resistor box,ecu,and 1 wire o2.
If your going obd1 or newer you will need,ecu with jumper,obd1 dizzy,4 wire o2,and with the injectors you can either stay obd0 and keep the resistor box or you can run the obd1 without the resistor box.
