Wiriing Harness
CRseX84
ok im gona do a LS/VTEC swap, with a GSR head, shuld i get a GSR harness ?? waht kinda ECU shuld i get also? im throwing it in my 91' CRX DX, if i do use the GSR harness do i have to do any modifications to it?? or any other harnes i would use?? and shuld i chip my ECU?? if so what shuld i chip it?? thanks for your help
I believe you need to send your harness to a place that can remake the harness for the vtec and MPFI conversion... or you cna buy the harness already made for you... Here
ok so on that sight there is a sub harness that i would use, but do i use the GSR harness or what? and would that sub harness make it so i would not have to modify the GSR harness? or what ??thanks.....
