Wiring An Amp?
Discussion in 'Members' Lounge' started by Ractive78, Feb 4, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    I got a 760 watt Sony xplod, and also a 1200 watt amp wiring kit. Iwas wonderig if the ground and the 12v wires would be way to big to use "4 Gauge", and if I should buy smaller wires, and smaller fuse "Fuse currently on 12v is 80 Amps" for the 12v wire? I was wondering if this could send to much power to the AMP, and cause damage. Any sugg.?
    Thanks
  2. pissedoffsol
    4g is plenty.
    i dount your amp is 760 watts if its made by sony.
    its probably 50x4 or something
  3. Ractive78
    Virginia, USA
    Do you think I should replace the fuse on the 12v wire to a smaller one "like 40"?
  4. pissedoffsol
    i run a 60 on my 75x4 amp
  5. Ractive78
    Virginia, USA
  6. RyanS2K
    RyanS2K Senior Member
    I run 50s on my two Alpine M300 300 watt amps, downstream from a 100amp circuit breaker by the battery.
    Ryan
