1993 Civic CX
LS B18B1 - not sure of OBD series (i guess it's a 1)
LS Manual trans
I believe it has the factory wiring harness.
I know people say it just plugs in, but I acquired a messy setup and I need to verify which plug and vacuum connection goes where.
The ecu is said to be chipped for 7psi.
I really do appreciate help.....
Wiring from drivers side. The plugs are are pulled taught so you can tell which ones longer than the other.
I don't know where the tube is for this. I might need to make one. But I need to know it's route.
This is one connector that matchs a plug from the 1st picture.
Another connector that I believe uses a plug in the 1st picture. AND sloppy wiring to the speed sensor that I am not sure if it is correct.
Another connector using a plug from the 1st picture.
Vacuum hose to where?
ECU splicing that I haven't been able to verify.
Some sort of splice that is confusing.
LS Manual trans
