Wiring at ecu help please!!!!
jac_smk
I am swapped a z6 into my 91 rex and need some help with the wiring at the ecu, everything else is done and double checked. I have the obd0-obd1 conversion harness installed just need to know what wires i need to swap or put in for the crank sensor and whatever else i need to do, any help is good help, thanks in advance!!! also can i run the obd1 injectors by simply changing the injector plugs and use the resistor box thats in the car? what wires to change for the z6 obd1 dizzy?
