Wiring B16a help needed
Discussion in 'HYBRID -> ED-EF / DA' started by salmaan_ali, Jan 10, 2006.
  1. salmaan_ali
    salmaan_ali Junior Member
    Guys im currently stuck.
    B16a is now in my car but its not started yet becuz of wiring issues ihave been facing
    I ran 7 wires from the distributor (B16). and matched them color to color with the ecu pins (C1,C2,C3,C4,B10,B12,B15+B17)
    I plugged seperate pins in their respective connecttors
    Everythign else is the same as i had previously (Most of my sensors are D/C as first im looking for spark in dizzy)
    As soon as i turn-on ignition. my Fuelpump starts for a sec PGM-FI light comes up and remains (dosent matter's i m also gettting colant temp sensor code as they are not connected... My MAp is also not connected but im not getting its CODE.. why???) but upon rotating the distributor there is no spark
    i changed my ecu... changed my dizzy but no results
    Im getting +12v at all four injecttors but dizzy is not firing
    plez help
  2. salmaan_ali
    BUMP
    plez help its urgent :cry2:
  3. wardatron
    wardatron New Member
    UNITED KINGDOM
    im in the same boat as you dude i want to run indivual wires from ecu to each componant ?
