low-keyseg92
I Swapped a running 94 ls motor into my civic. Ok so far so good. All the plugs went together and had no problems. Then the car would not start. I started checking grounds, fuel pressure,spark,compression.....all are good. The wiring harness at the strut tower however does not match. The wires are in different spots. The colors dont match...ie, blu/grn to blu/grn wht/red to wht/red etc....then some are not in the right spots (open) that is. Either way I have the manuals for both cars and have followed the diagrams and thought I had everything in the right place, except the Integra harness has 1 red/ylw wire not used. I searche don here for diagrams for the wiring and found none. Does anyone know where I can find a diagram of the wiring for this swap. I have talked to several people and they say it should plug up and nothing change. I had a D15b7 in the car before. Any help would be appreciated. BTW im new here but have been on onepoint for awhile. Thanks again
