Wiring Diagram for a D16A6
engelsp
Hi
Were can i find a wiring diagram for a D16A6 Engine i need to install a tach (automerter 233904) and i dont know wich is the tach signal wire.
Thanks for the help.
autozone.com repair section...
has everything on pre 1995 hondas
wire diagrams included
if you have a non SI i think you can just put in an SI gauge cluster...
plug and play with a stock SI tach...
unless you;re going for the rice look
Thanks for the help but i still dont know the color of the signal wire.
The Engine was from a CRX Si 1988 my HB is 1991
Thanks again
Thanks for the help theodor613 im going to check the wire on the distributor, but i was checking a wiring diagram and there are 3 blue wires BLU/GRN, WHT/BLU and BLU/YEL.
thanks theodor613 for all the help.
Thanks reckedracing for the wiring diagram.
