so where is the Intake air temp sensor hooked up on a obd1 harness and where does the Knock sensor connect to from the ecm and to the sensor itself and how do i know what side the main engine harness connects to the junction box and ecm.. they seem to both fit to either like left side to right side right side to left ..Help.. ....??
which harness are you using? knock sensor is in pin d3 on ecu link shows ecu and so forth 2nd wire goes to ground. http://hondaswap.com/reference-materials/ecu-pinouts-28667/
which harness are you using? the knock sensor goes in pin d3 red/blue wire the 2nd wire goes to ground
