wiring gauges
Discussion in 'Body / Exterior / Interior / Cosmetics' started by eg6sir, Oct 6, 2005.
  1. eg6sir
    ok..i'm trying to wire up some white face gauges...what are the red and black wires for...and where do they go...
  2. eg6sir
    anyone??
  3. Celerity
    Celerity Well-Known Member
    You can't be serious.
  4. eg6sir
    im a noob when it comes to wiring
  5. ripperbone
    ripperbone angry bear
    Oklahoma
    red is power and black is negative
    so i take it your wiring in either indiglows or reverse indiglows.
    if so splice the red wire into your light brigtness switch (you'll need to find which wire gives power when you turn on the lights) and the black goes to a ground.
  6. drpenguin
    drpenguin Senior Member
    Salem, Or
    I got a fuse tap. its a think you take a fuse out. I chose my lights so the gauges come on when the lights do. you put the normal fuse in the botom, and a what ever size in the top. I dont think your supposed to go above 5amp or whatever it is. I just hooked the red wire to the wire off the tap and the black wire to the steering colum
  7. Celerity
    So the gauges have only a mainpower wire that turns the lights on automatically ? You can't get them powered on / lights off ?
    -> Steve
