Im trying to diagnose a problem with the electrical on my Crx.
the car runs fine with the headlights off, but once you turn them on the problems start.
Symptoms:
The clutch pedal sparks when it contacts the retraction spring.
The temp gauge goes immedialty to hot
The lights throughout the car dim and flicker and often cut off for a sec.
What ive tried:
I made sure my main grounds were good and they are.
Check the white boxes the ground for the headlights, and resanded their contact points on the chassis.
Other:
I found that if i put my test light on my temp gauge metal casing ( aftermarket mechanical style) It will light also, and it is not supposed to have power at all.
I hooked my test probe and im seeing that no matter where on the engine i touch ( metal like the intake mani and stuff) the probe lights up... thats not supposed to happen right?
As i said all my problems happen with the headlights on, with em off the car functions flawlessly.
Please help me out here, im stuck on this and need an experts help.
Symptoms:
What ive tried:
Other:
