Wiring Harness Issues
ok... i really hope i can get some answers on this... i put the JDM B16A (OBD2a) motor into my 98 Civic EX a while ago with the 00 Si harness and 00 Si P2T ECU, but that wasn't workin right so i put a 96 EX harness and P72 Ecu into my car cause people said it was what i was supposed to use in the first... <_< well... everything is in and my damn car sounds like a lawn mower, it idles really high (like 2K), and it has absolutely no power... can someone please help me out!!!
nevermind i got it working... the jackass who sold me the wiring harness had the #4 injector cut... but now i have a high idle problem!!!
welcome to honda....
high idle? how high? like 2-3k high or 5-6k high?
if its REALLY high, like 5-6k, it could be your IACV.
if it's just idling up and down from 100rpm to 3k rpm or so, your TPS could be fucked up.
Originally posted by 1phatcivic28@Nov 11 2003, 01:01 AM
it idles from 800-2K... it bounces back and forth about 5-10 times, then settles back at 800... and where is my TPS located???
i had that same problem before with my old d16 - it was the map sensor.. . . . . .
unplug your TPS and see if it changes anything.
then unplug your map sensor, and see if anything changes.
also, the TPS on B-series motors is riveted on. well, at least on obd0's. not sure about obd2....if it is riveted on, you'll have to drill it out.
check for vacuum leaks and then reset your idle.
