Wiring Harness Problems
Discussion in 'HYBRID -> EG-EK / DC' started by breakdancingbob, Mar 21, 2003.
  1. breakdancingbob
    breakdancingbob Member
    I got a 90 crx and I just put in my b16a. I noticed most of the wiring connections on the car and engine don't match up. the wiring harness is uncut. what do i need to do.
  2. breakdancingbob
    could it be that they put a 2nd generation b16a on a y1 tranny and the plugs are different?
  3. solblu
    solblu Senior Member
    Ricer
    What harness do you have?? If it's the one from the car what kind of CRX do you have??
  4. breakdancingbob
    I have the complete wiring harness from the b16a and the complete wiring harness from my 90 crx si.
  5. solblu
    Ricer
    OK here's why they don't line up.
    1. the B16 harness is JDM and right hand drive.
    2. The DX harness if DPFI and doesn't even have all the wires you need.
    You can use the B16 harness to make a harness, or get a 4g Si harness and use it.
  6. EFtypeR
    EFtypeR Junior Member
    I won't be a dick like everyone else....I just did the same swap....You need to swap the CRX harness with the JDM one...I know, it will take some time, but then you can use the CRX harness and mod it to work with the PR3 computer and fix the dist. and V-tec wires. Look up some SCC magazine back issues, and even a Honda Tuning current issue, they will have all the info you will need for the convergence. Also there is a very informative swap site, look up old posts, that details all the pinouts of the B-16's ECU. That is what I used, and my car runs nicely now. Good Luck, post back if you need more help....
  7. bossman032
    bossman032 Senior Member
    ECU PLUGS: A= GREEN PLUG, B=Black PLUG, C= Black Plug
    After **A PLUG** IS **B PLUG** AND THEN**C PLUG**
    A Plug on the ECU is =18 pins
    B Plug on the ECU is = 20 pins
    C Plug on the ECU is =16 pins
    On the Connectors that plugs in the ECU.
    A PLUG @ A8 = Vtec Solenoid
    A PLUG @ A17= IAB Solenoid Not Needed!!!
    B PLUG @ B5=Vtec Pressure Switch
    B PLUG @ B19=Knock Sensor
    C Plug @ C8= 2nd O2 Sensor
    Hope this helps on the wire shit..
    let me know if you confused..
  8. bossman032
    Just use your CRX Si wire!!!
    Don't need the b16a harness sell it on ebay and get a clutch or something..
  9. timEspeed
    timEspeed Senior Member
    I'd suggest you contact HAsport. They got all kinds of wiring conversions and they do a quality job. Being I have a lack of knowledge in electical systems as it seems you do too, this would be the best way to go. Easy plug and play mod.
