Hi i have a zc engine that i just put into my 5 spd 89 crx. From what model car and what year do i have to use the wiring harness from. Also will a obd 1 ecu work for this swap
not if he has DPFI. Si has to modded to work on DX chassis, use the fucking DX harness and modify it, been done millons of times take like 1 hour.
gotdamn n00bs fucking search. Use your stock haness and convert to MPFI. Only way to use a OBD1 ECU is to get the ECU jumper harness and OBD1 Distributor FOR THE DOHC ZC. Search will answer your questions
