Wiring Harness
95egswap
Richie
The wiring harness is what the O2 sensor is plugged into correct? Cos the guy that owned my car before me cut the O2 sensor back after he tuned it for not running the O2 sensor. So I need to know if when i get my new motor if the wiring harness will have an O2 sensor hookup. thanks....
Yes, the Oxygen sensor is plugged into the wiring harness. If your unsure if yours still has it, then look around for an unused plug for it and make sure it is still wired up. If it isn't or if you are not sure then you would probably be better off buying a new uncut harness or making sure the new motor comes with one.
i think the o2 sensor plug on my wiring harness is cut too.i just cant seem to find the plug.can anyone post a pic pointing out the o2 sensor plug on the wiring harness?
