wiring harness
mozzandherb
As far as the wiring harness goes for a h22 swap into a 92 Accord, did most of you just use the wiring harness that came with it or did you buy a special wiring harness? I know there is a wiring harness that you can buy from which makes things easier have any of you bought this harness?
use the harness in your car, and add wires where needed. its the easiest way to do 99.9324234234234% of honda motor swaps.
[post=518168]Quoted post[/post]​
Thats what I call vaguely precise. leaving 0.0675765765766% of us screwed.
Originally posted by abdelsol+Jul 1 2005, 01:41 PM-->
pissedoffsol
[post=519319]Quoted post[/post]​
that small percentage is the people that need to read more or ask detail questions. swaps are easy but not that easy. but as pissedoffsol said use the harness in your car, and add wires where needed. its the easiest way to do the honda swaps. your harness is a 100 way and the 99.9% is you doing the rest of the wiring. it might take a couple of tries but you will get it :)
