Wiring help for fan!
Discussion in 'Civic and CRX - EF' started by I Ride Dumped, May 7, 2009.
  1. I Ride Dumped
    I Ride Dumped New Member
    Hey guys I'm new to the forum so I don't know if this is posted already or not but I need help!! I just bought this car a few weeks ago and don't know whats all with it until it doesnt work! And I found out today that my fan is not turning on! I had this same problem with my CRX Si that I had awhile ago. But I don't remember how my mechanic wired it. Can I run an inline fuse from the starter solenoid to the fan then run it to a switch and put that in the cockpit! Please someone help me out! :ph34r:I will give cookies to who ever helps me!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    first unpluf it and run a wie straight to it from the battery to see if its good or not
  3. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    could be relay switch but yea....hook it up direct to battery first
  4. I Ride Dumped
    Ok Ok. And if it runs what can I run the positive lead to?
  5. AHHVTEC
    Alabama
    yeah you can just run wires to it with a fuse than to a switch in the car, but if it works. its prolly just a bad fan switch
  6. D16SiHatch
    D16SiHatch New Member
    spend an extra three ounces of effort and wire it up properly. running your radiator fan off a switch is ghetto and unnecessary. once you determine the fan is good check the relay, and then check the 2 prong coolant fan switch on the back of the block. pull the wires off of the switch and touch them to eachother. if the fan comes on, then the switch is bad, if it still doesn't come on then most likely the switch is ok, and the problem lies elsewhere. (i.e. break in a wire, fan relay)
  7. CAFROG
    NOR-CAL
    I still say fan relay switch....changed them a few times and they have been the problem in the past....
    But I don't know what the coolant fan switch on the block look likes on your car so that may be worth looking into as well.
    Relay first IMO
