basically, noone had obd2 motors instock when i ordered, so i made due.....I have the helms for the 97 lude and the 94 teg to compare wiring..but so far she is only running on cylinders 2 and 3...and throwing the following codes:
4
14
15
21?
if anyone has done this....i would really appreciate the help, as there are quite a few wires left over after i ran the wires from the Crank sensor area to the dizzy...and now there are left overb wires from the oem 97 external coil plug, which isnt needed since my obd1 h22 motor has an internal coil (JDM)
my car is the following setup:
car - 97 base lude
engine - 95 JDM H22a
engine harness - 97 base lude (external ignition coil)
ECU - JDM P13 with conversion harness
dizzy - JDM H22a dizzy (internal coil)
Thanks in advance for any and all help!
4
14
15
21?
car - 97 base lude
