wiring info needed help
Discussion in 'HYBRID -> EG-EK / DC' started by mathondamn, Feb 18, 2004.
  1. mathondamn
    mathondamn Member
    Hey can some one give a run down on what i need to do to get a obd2 motor into
    a obd1 car. So far ive heard the fuel injector needs a resistor box to run off obd1 ecu. Thats suposed to be located in the obd2 eng harness. also need to run obd1 distibuter. If any body has any links or onfo in this please let me know
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    only pre-obd uses resistor boxes
  3. mathondamn
    mathondamn Member
    so i dont need to use resistor box to run the obd2 motor with a obd1 harness
  4. E_SolSi
    nope ... im running an 01 ITR engine using my 93 sol harness (just changed the plugs)
  5. mathondamn
    mathondamn Member
    so put the plugs from my obd2 harness on to the sohc vtec harness with no resister box
    so it is unnessary to find an h22a obd1 harness and switch over the plugs. so your saying the sohc's harness will work for this?
    what about the distributer do i need the obd 1 or 2
    you have no idea how mutch this info helps thank you
  6. E_SolSi
    i have not done an H series swap so i can not say if any of this is correct for an H series
    but for my B series swap
    i changed the plugs for the injectors, distributor, and i used an OBD-1 alternator (could have just switched the plug for this too)
    then added length to whatever plugs wouldnt reach
