wiring issue on b16
Discussion in 'HYBRID -> EG-EK / DC' started by civicious, Sep 5, 2003.
  1. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    i said in another forum about my wiring all getting burned up thanks to a fuel leak....
    i got another harness, but this one isn't custom-made like the last one i had, so im gonna have to do some wiring on my own...
    my question is, on the driver's side, there's a connector that has ( i think) 10 wires. on the B16 harness, theres 13 wires. what goes where, and which ones do i not need?
    help would be greatly appreciated.
  2. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    what kind of harness did you get to go on the motor? And make sure that you have the right plug connected to each one.
    Darin
  3. civicious
    Houston, TX
    the harness i'm using for the motor is from an obd0 b16....my car is an obd2 98 civic
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i think you are going to have some serious problems trying to get that configuration to work...
  5. civicious
    Houston, TX
    is all that just like the gauge wiring? or is there more to it than just that?
  6. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    There is more to it than the guage of wire, the plugs are different, the wires go to different places, and it connects to the chassis different. So basically it is good or extra wire.
  7. civicious
    Houston, TX
    i meant gauge, as in gauges, i.e. speedometer, tach, etc.
    so is the plug thats on the drivers side just the wires that go to the gauges, or is there more stuff there?
  8. seanjuan
    seanjuan Senior Member
    Twin Cities, MN
    the wires going to the gauges come from the ecu
    the harness on the driver side of the motor are for things like ignition, lights, etc.
    I don't know what all the wires do though
    but you are going to have alot of probs because the obd0 and obd2 plugs are totally different [to the best of my knowledge]
    I think you would be better off spending some money and getting an engine harness from a 6th gen ex or si or something
    best of luck though
