Wiring it all UP!!
Kovalski
Ok so I have the p08 and old d15b7 harness for the new d15b vtec motor but need to run vtec, after that is all done should I be set to fire or is there something else i'm missing? I know I want to go get it tuned too. If there is anything else that one of you honda gods know of can you help us out?..Thanks agian.Kov
If your d15b was like mine and didnt come with the vtec pressure switch I would try and get that sooner then later, so you can at least fully run the vtec. Other than that I'm pretty sure you have it all covered, I'm doing the same swap in the same car only I'm using a wiring harness from the si motor, d16.
