wiring JDM b18b
Discussion in 'HYBRID -> EG-EK / DC' started by sspire, Nov 3, 2003.
  1. sspire
    sspire Junior Member
    (JDM b18b in 92 VX) ok i have 2 problems first passengerside harness is on drivers side of of new motor and viseversa, how do i go about relocation? second there are 4 passengers side junctions but olny 3 on either side of the motor, am i overlooking somthing or does the 4th nolonger serve a porpose? i can give you pictures, my name on aim is WeRt765. appreciate any and all responces.
  2. smashed4thgen
    smashed4thgen Senior Member
    is the motor obd1 if so us your factory harnnes
    it it isnt ond1 get obd1 dizzy ecu and shit and u will be golden with factory wirring
  3. pissedoffsol
    you need to give us more info.
    what year motor?
    what harness are you attempting to use?
  4. sspire
    the motor is JDM and its a 95(motor not car) everything matches up its just getting the harnesses to the opposite side of the car.
  5. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Thats because the jdm motor came from a RHD car. Try your old engines harness, I believe you may have to lengthen wires.
    Correct me if i'm wrong guys...
    <---NooB
