Wiring orientation for O2 sensor
Greenery18
Just installed my DC header in my IntegraLS, but when i removed the O2 sensor from the stock header I accidentally pulled it out of the 4 plugs the wires go in. Now i don't know the correct way the 4 wires fit in, and there are tons of combinations.
I have been trying combinations for the last hour, and everyone i have tried still throws a CEL. Please help!
Somewhere online said it was like this:
1. GRN 2. WHT
3. BLK 4. BLK
but i tried that to no avail...
I did the same thing in a civic d16z6, I just guessed and first try it worked, maybe its the smae. looking at it. Top right white leeds to white coloured wire, top left green leads to a green/white stripe wire, and the 2 blacks just cross over once.
hopefully that can help u
and clear the codes between tries. The code will reappear even if you get the combination right, unless you reset the ECU.
