Wiring Problem On B18a1 Into Crx Si
Discussion in 'HYBRID -> EG-EK / DC' started by pdqcrx, Apr 9, 2003.
  1. pdqcrx
    pdqcrx Member
    Va.
  2. pissedoffsol
    looks like a knock sensor to me...
    but i didn't think the b18a had a knock sensor.... i could be wrong.
    what ecu are you running this off of?
  3. pdqcrx
    pdqcrx Member
    Va.
    I'm gonna try the stock ecu first. Been told it will run it just not at peak output. When Chris has more cash he said something about having one burnt with a header and cold air intake.
  4. tres
    tres Junior Member
    that is the knock sensor you need to get the plug from an integra and then wire it to the ecu yourself it goes to pin 23 on the a plug :rolleyes:
  5. solblu
    solblu Senior Member
    Ricer
    Well if you are running the stock ECU you won't need it if there is no plug on your stock harness for it. You don't have any left over plugs do you?
  6. Civic_88ls
    Civic_88ls Senior Member
    everett, wasington
    Thats not the knock sensor, its the water temp sensor. all u have to do is change it to a ob0 water temp sensor
    At least i think it is because when i put my ls in my car i remember changing the water temp sensor and it was the same thing, so thats what i think it is.
  7. alterboy82
    alterboy82 Junior Member
    does distributor wiring off of si work on distributor on obd0 b18a1 integra? anyone here do the si to b18a1 swap while using stock si ecu? i am swapping to b18a1 soon, and need some help. Thanks
