wiring problem
Discussion in 'ECU's, Electronics, and Tuning' started by jcivic, Oct 13, 2002.
  1. jcivic
    jcivic Junior Member
    :( my 98 dx harness does not plug into my 00 si ecu.the middle plug does not fit.can anyone tell me what i can do?can i rewire the harness to fit ,or is their an adapter for this situation?
  2. pissedoffsol
  3. jcivic
    :unsure: come on guys any help outthere?????
  4. Baker
    Baker Senior Member
    Schaumburg, IL
    well, either you re-wire your harness or buy an obd2.a to obd2.b conversion harness for around $200. I'm sure you have other ptions but i don't know what they are.
  5. honda_power69
    honda_power69 Member
    my advice, find a junk yard somewhere near you and look for a 99-00 civic si that has been absolutely totaled. The single plug you need to re-wire your harness should still be intact. Most places will try to make you buy the entire harness, so dont tell them exactly what you're lookin for, just tell em what kinda car. Buy a little something or other off the car from the interior and just snip that plug off ;)
  6. Baker
    Baker Senior Member
    Schaumburg, IL
    even if he gets that plug he'll need to rewire more than that, the wiring setup is different and all the wires on the center plus are not the ame just in different position. They are kinda scattered in whats been changed.
  7. B16
    B16 Super Moderator VIP
    yay area, CA
    right, he needs to use his dx harness, get a jumper harness to go from obd2.a to obd2.b, and run the other wires needed, i think that is your best route out. or do what i did, and get a p28, go back to obd1, and use an obd2 -> obd1 jumper harness.. obd1's are easier to tune.
  8. Baker
    Baker Senior Member
    Schaumburg, IL
    ok, if he wants to do obd-1 he neds to get a 96-98 ex harness and a obd-1 jumper harness and ecu, thats the easiest route, the DX harnesses are garbage.
    if you want to stay obd-2 get a EX harness and a jumper harness from obd2.a to obd2.b You can use your DX harness but theres a lot of garbage you have to run.
    You can also use a SI harness but you'll have to re-wire the dash harness or get a new one.
