Wiring problems, VTEC Oil Pressure Sensor
nq8s
b18c1 in a 95 cx hatch
I got a diagram
the knock sensor (done),
the VTEC Solenoid (done)
and the VTEC Oil Pressure Sensor?, Blue, D6 (NOT done)
On my motor male side, (from the wire harness with the pins) there is a solid blue.. but the side for the ecu harness through the firewall there is no extra hole to stick a wire in plus the solid blue is connected to something else to the ecu?.
Have any idea where I run the VTEC Oil Pressure Sensor wire?
Do I need to tap the line from the solenoid.
reply would be greatly appreciated, doing it now
