wiring problems
h22bubbleback
today i change my wiring harness over to an obd1 sohc vtec harness. i hooked up everything exact. however. on my b16 head i have obo-0 injectors. so i used obd 0 injector plugs on the harness. i had this setup on my previous harness as well. i cut the old plugs off and splice the obd 0 plugs on. i simply just twisted the wirings together(this worked on my previous harness). i go to start my car..it fires and cranks over slightly but sounds like injectors are firing completly out of order so i put them on every single possible combo and same or worse result ea. time. sounds horrid.....my question is..could the connection be to weak some were in my plugs because i simply just twisted the wires together? should i soder them?
:cliffs:
changed harness
cut and spliced obo-0 plugs onto obd1 harness
now car wont start :(
obd0 injectors are peak-and-hold.
obd1/2 are saturation.
youre gonna have to wire up a resistor box to run the obd0's.
i had no problems with the obd 0 injectors before though
