Wiring Problems
turbob18c
ALright i own a 97 civic hb dx
it had a alarm aftermarket i ripped it out
i have the motor out with the wiring harness
there is a green plug that you disconnect to take the harness out
when i turn the key on all the way my lights work but heater wont turn on, radio doenst work and fuel pump doesnt go
is this becuase i took the alarm out or because the green plug is not connected?
thanks for the help
thanks for the help
[post=462794]Quoted post[/post]​
depends on how the alarm was installed because you can hook up an alarm to the fuel pump, radio also but why would you? I would have to guess its the plug it sounds like thats suppling power to your ignition harness. You may have a fuse blown (long shot but something may have shorted out should be a larger fuse in you engine bay)
