Wiring Problems
Discussion in 'ECU's, Electronics, and Tuning' started by SixtySecondAssassin, Jan 29, 2003.
  1. SixtySecondAssassin
    Austin, TX
    im trying to wire up a sir II b16 into my 92 cx. so i pull the old motor out and label everything on the wire harness. then i started to plug everything in on the b16. all the plugs went in smoothly with the exception of the evap purge solenoid. it was not on the back of the manifold like on my cx. now my map sensor on the b16 was an external unit the mounted on the fire wall. are there external eps's also?
  2. SixtySecondAssassin
    Austin, TX
    ttt
  3. longlee
    longlee Junior Member
    just unplug the mapp plug and plug it into the new motor.....im not so sure about the evap solenoid yet...
  4. civicSiR1
    civicSiR1 Senior Member
    EVAP PURGE SOLENOID? it's located right on the TPS....be sure to hook up the ground too...
