Wiring question PLEASE HELP!!!!!
dansace
Member
I installed my newe d15b last night and must now hook up the v-tec wires. Thre are two wires I have to hook up-green/yellow and blue/black. The question is there is a black wire grouped whith the blue/black plug which I am assuming is a ground. Can I ground this any where or does it need to be tied into the ecu grounds?Thanks
Actually, the black wire can be attached to any convenient spot on the chassis in the engine bay.
For mine, since I am already running the other 2 VTEC wires with looming through the firewall, I ran an extra one for the black wire and spliced it to one of the multi-ground wires at the ecu harness.
