wiring questions regarding alternator
KYL174
Member
i know i should've used the engine harness of my 98'type r motor to plug into my 92'si hatch. but too late because i did not know this at first. So i ended up buying a obd1 distributor, but my problem now is the color code of my obd1 stock wiring to the obd2 type r alternator. the stock plug on the obd1 was cut and used the obd2 plug from the type r alternator. what color wires goes with wat??????help.this is the only thing left before i drop the motor into my car.
