Wiring questions...
Discussion in 'Car Audio / Security / Electronic Accessories' started by George777, Jan 11, 2007.
  1. George777
    George777 ^^ Likes Bewbies
    With your mom
    I've got 2 Audiobahn subs and a ported box...I ordered my amp so I can install everything into the car, but I need to wire the subs and install them into the box.
    Is it better to wire them as parallel, or as a series? And should I wire it as 2 ohm or 4? Also, should I run it as 1 channel, or 2?
  2. ThatGuy4life
    ThatGuy4life The Riced Sleeper
    Albuquerque, NM
    From personal experince (I do custom car audio installs) audiobahn's subs are put together rather cheap, normally all subs I install I would drop to a 2ohm load or 1ohm load and run on 1 channel, but I don't want you to go blowing your subs so to be safe, wire them parallel off of 2 channels
  3. neonmike
    neonmike Senior Member VIP
    before you wire it you need to know what the amp is stable to ie: 2 ohm 1 ohm etc. get the info and let us know.
  4. George777
    With your mom
    Thanks...When I get it I'll let you know.
