wiring vtec
Status
Not open for further replies.
typesiracing
i don't have the original vtec pressure switch plugs, so i need to know what pins go to where....if you look a the actual sensor you can see two pins one on top and one on the bottom.....i need to know which one is ground and which one goes to ecu....even if someone can look at theirs and tell me which one is the black wire (top or bottom)....i believe the bottom one is black(ground)...thanks guys
This is not Swap-related. This is the Swap-related forum.
Try again in the right forum.
:locked:
Status
