wirring for a CD player
shortbusrebel07
ive came to a dead end fellas im putting a CD player in my 89 hatch and ive ran into a few wires that dont match up here is what i have left comming out of the car's wirring harness:
red with black stripe
red with green stripe
red with yellow stripe
copper with black stripe
copper with white stripe
white with blue stripe
yellow with red stripe
blue with yellow/green stripe
and here is what i have left comming from the CD player's wirring harness:
white
white with black stripe
purple
purple with black stripe
green
green with black stripe
and then i have:
yellow-amp wire
orange- amp wire
i need to know which ones match up to which and which ones from the car are the rear speaker wires so i can cancel them out (i dont have rear speakers)
1) Go through each speaker and take them out.
2) Check to see which wires are conneced to the speaker
(I.E. i f the front-left has a copper with black stripe, and a red with black stripe... hook it u to the front left output channels on your deck, white and white black, i think. ???)
But yeah... just check the speakers too see which color wires are hooked up to each, and do your install. It helps to right down which wires are hooked up to which speaker so you dont get confused. then use your notes.. and install.
Good luck!
