won't rev beyond 3500 rpm
ok guys and honda techs...............i just did the swap
i have a d16z6 head with a d16y8 head and i am currently using a dizzy from a d15b7 motor
(my car is a 1993 honda civic ex it came with a d15b7 (canada)
i am getting a code 4 code 20 and i think code 36
i dont know wtf code 36 is???
i am using a p28 ecu
i get the effect and codes even when i use my p08 ecu
i think its the dizzy causing the problems
any advice please reply thank you :blink: :blink: :blink:
4- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 85-98
CKP Sensor (Crankshaft Position Sensor)
defective circuit or unplugged / defective sensor
20- Accord Civic CRV CRX Del Sol Odyssey Prelude
90-98 88-98 97-98 88-91 93-97 95-98 92-98
Electrical Load Detector
I'd fix those first before trying to troubleshoot the dizzy?
Are you sure it's 36 and not 45?
ok i am goin 2 check over the timing belt and the tiiming setting
my car worked fine today 4 a while until it started 2 bogg out when i crossed 4000 rom
dizzy looks good
thank u
ok where the f%^k is the crank shaft sensor located????
the timing is dead on
ok my timing is dead ON
i am goin 2 try and switch dizzy
ohhh my wire harness has 2 plugs that go into the dizzy one plug has like 6 wires the other plug has
2 wires (black and blue)
the dizzy that came with the motor(d16y8 head)has only 1 plug
any ideas (i am using the dizzy off my old motor d15b7)
how can i check the signal for the crank position sensor....what color wire is it????
mayb i have a bad wire....lol
thank guys
[ok guys
i switched the dizzy today and replaced it with another dizzy from a d15b7(AND YES IT FITS ON A D16Y8 HEAD)
AND EVERYTHING WORKS FINE
the motor doesnt pull strong as it should so i am goin 2 triple check the timing and reset it!!!!!!!
i will let you know hoe it works out
