won't rev past 6500 rpm
Discussion in 'HYBRID -> EG-EK / DC' started by LPR Racing, Oct 17, 2005.
  1. LPR Racing
    LPR Racing Junior Member
    <span style="font-size:11pt;line-height:100%">I really need someone help out there, i did a swap on a 96 Hatch DX, i put a GSR in it. I used the stock Dx wire harness. Did the repining for IACV, match the wire for the CKF sensor, ran the vtec and the knock sensor inside and am using an OBD2a adapter harness with a P28 chipped ecu. After the swap was finished car started no problem. Except it wont rev past 6500 rpm. I changed distributors, from brand ODD-1 to Brand new OBD-2 dizzy. I changed computers, wire harnesses and nothing seems to work. It still won't rev past 6500 rpm. Can anyone help me</span> [​IMG]
  2. reikoshea
    Dallas, TX
    have you driven the car? sounds like your vtec isnt wired. if you are not in gear (clutch doesnt count) the vtec doesnt engage, and your revs are capped about that point.
  3. killercannible
    killercannible Senior Member
    Thats not true, even if vtec dosn't work the ecu will not lower rev limiter especially on a chipped p28 which probably has the rev limiter removed. Run through your grounds and make sure everything is straight.
  4. reikoshea
    Dallas, TX
    well i know its true on an H22. if im stupid and try to REALLY drive before the car warms up the engine hits a rev limiter at 6300 RPMs.
  5. formby
    formby learning in progress
    yeah my obd0 lsv wouldnt pass 6.5k when my vtec fucked up
  6. PhyRe
    PhyRe Senior Member
    ct
    when i first did my swap last year(gsr into 93 dx) i had two chipped ecus that i tryed using. one with rev limit of 86k and one that was unlimited and both limited at 7k when my vtec wasnt wired right. its been proven tmie and time again. check your wiring
  7. B18C1civic96
    B18C1civic96 Member
    5-CARS IN FRONT OF YOU
    check your wiring here this should help
    link
  8. reikoshea
    Dallas, TX
    and if you want to keep the traffic local..you can get the same info out of our reference section:
    LINK
