wont start
Discussion in 'HYBRID -> EG-EK / DC' started by tymasterflex, Aug 20, 2003.
  1. tymasterflex
    tymasterflex Member
    i finished the swap, started the car and it would die right away...ok no fuel. so i put more fuel in, and then try to start it. this time it turns over, but very slowly. wtf? is it battery? my deck still pops to life when i turn the key is in "on." :huh:
  2. endlesszeal
    endlesszeal Senior Member
    it could be anything.. maybe the distrubator? bad plugs? need new caps/rotors? clogged fuel filter?
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Could be the battery is not fully charged. Your radio takes less power to turn on than your car. Charge it up and try. You may also have a bad ground.
  4. tymasterflex
    tymasterflex Member
    alright it charged the battery, its turning over faster now, but it wont start. BUT if i put the gas pedal in, it will start, as soon as i let it out, it dies. i just dont understand how i can have like 4 different no start scenarios!
  5. Accordturbo94
    Accordturbo94 Senior Member
    make sure you have a bit of tension on the throttle cable to the body! and maybe adjust your idle to accomodate! Does it stay running when you get it started or will it kill without giving it a little gas
  6. gyallis
    gyallis Senior Member
    Bronx NY
    Check battery, distributor, grounds and maybe a bit of starting fluid.
  7. Krazy4379
    Krazy4379 Member
    :werd:
  8. tymasterflex
    tymasterflex Member
    it wont start unless i give it gas, and it also wont stay running unless i give it gas. so it will run, until i depress the gas pedal all the way. ill check the tension and idle, see if that wont do it.
  9. tymasterflex
    tymasterflex Member
    HELL YES! i adjusted the throttle cable, and she fired right up. you the man krazy.
  10. Krazy4379
    Krazy4379 Member
    Don't thank me thank AcoordTurbo94.......he said it first but i was about to post exactly what he said till i saw it......no need for a double post but have fun man.
