won't start
Discussion in 'HYBRID -> EG-EK / DC' started by breakdancingbob, Oct 26, 2005.
  1. breakdancingbob
    breakdancingbob Member
    I just put my b16a in my 93 del sol and I am getting spark but it is not firing. It acts like it is not getting fuel. Any Ideas?
  2. smooth95
    smooth95 Senior Member
    South Cali
    checkthe fuse in the fuse box by the battery its the one with fi on it next check the fuel injection relay right under the glove compartment
  3. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    it is possible that the fuel lines could be dry you may have to keep cranking it until fuel can get to the injectors, how long did it sit with the sines open? if more than a few days it's possible.
  4. breakdancingbob
    it sat for 2 days. I have fuel at the intake
  5. jimboburgess
    nyc
    Doubt it would be the fuel pump, filter.
    Double/triple check all your lines vacume lines, everything, i am sure you have done that though.
    Check the fuel presure regulator? See if anything engine side involved in giving gas to the engine is acting odd
  6. breakdancingbob
    fuse 18 was blown, but it still doesn't start. also, does the obd0 resistor work obd1. I was told it will, but I am just checking.
  7. Scorchin Civic
    Scorchin Civic Senior Member
    Irving, TX
    Might want to try and get some OBD1 injectors because I don't think you can use OBD0 stuff with an OBD1 car besides the motor. I could be wrong but it's my $0.02! :p
  8. breakdancingbob
    I just found out that only the plugs are different. so that isn't my problem. I tested my main relay too, and it was good.
  9. breakdancingbob
    I have power to my injectors, but no ground pulse.
