last week driving down the highway about 1/2 mile from my exit, saw my temp guage going up. so on the offramp i turned my heat on full...well it blew cold air and temp was climbing quick, so right after i got off the highway i found a spot where i could pull over and i did. when i turned the car off the temp was all the way up on red. i got out, discovered i had zero coolant and there was coolant all over the back of my motor. me and my dad trailered the car home.
the waterpump's gear froze in place, ripping my t-belt in the middle and throwing my car off time(pretty sure). luckily i the car was running fine when i turned it off, just hot...which is bad enough. so i replaced the water pump and t-belt trying to time it with the cam marks and the crank mark to time it correctly. now it turns over fine, but it won't start. i smell gas so its getting fuel, its getting power to the ignition coil and the plugs/wires/ignition coil/ distributer rotor are all new. i just really would love it if i didnt have to take the t-belt off again to re-time it. any input or ideas?
thanks
thanks
