would i need to change suspension????
Discussion in 'Wheels / Suspension / Tires / Brakes' started by b18delsol, Jun 23, 2004.
  1. b18delsol
    b18delsol Member
    if i was suppose to put a h22 in my del sol would i need a new suspension??? if i do; den wut kind of suspension do i need????
  2. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    Why would you need new suspension? My old room mate just put a H22A in his 4DO Accord he did not have to change anything but the people that did his swap put in new axles.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    The H block is about 150 pounds heavier than a D block setup- so yes, it's advisable to change your suspension to suit the new front end configuration. The suspension in the Accord is already set up for the weight of the F/H blocks, so you really don't need to change much.
  4. integraslut78
    KiLLa kALi
    Sorry to lead you in the wrong direction b18delsol
