would i see gains with a aftermarket manafold
Discussion in 'Engine Building' started by competitiveaudioman, Oct 6, 2007.
  1. competitiveaudioman
    competitiveaudioman New Member
    i have a b18b with the b16 pistons. i was wondering if i got the skunk 2 or blox intake manafold if i would see noticable gains. im running a header, intake, fuel pressure regulator and full exhaust. would upgrading the tb help also?
  2. Velcroy
    Velcroy Limited Civic Skills
    I'd say you would.. not sure though.. lol
  3. 88blacksi
    88blacksi Grandpa
    I have a b series skunk2 manifold and stock b series intake manifold. In comparison the skunk2 has bigger ports and wider tubes. I have a upgrade oversized TB as well and it does gain some hp but not that much.
  4. Hatchyspeed
    Hatchyspeed B20/TypeR Head
    Florida
    you will fell gains but not much.. you should add a throttle body too that would be wise a little more power/ torque gain i belive the skunk2 mani add8-12 hp / 6-9 torque.. you could look it up on the skunk2.com n look at manifold dyno's
  5. dtob
    dtob New Member
    I don't think you would see that much of a gain on a b18b with stock valvetrain but who knows. Maybe with aftermarket vavletrain or on a dohc vtec with cams, pnp, etc.
    What I would do is save some more money and do some headwork or go ls/vtec. You would see more gains for the money in my opinion.
  6. 88blacksi
    88blacksi Grandpa
    The suckie part is the PCV valve is making my intake oily.
  7. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    so replace it, its about 2 dollars.
    i run an aebs manifold and i recommend it over the ones listed. its cheaper and i think just as good.
  8. norcalgsr
    NorCal
    I have an AEBS manifold on my B16a.. it's basically an ITR copy with some slight improvements and I like it. It also has bosses on the underside of the intake runners to add nitrous if desired.
    I agree with a stock valvetrain you probably won't get much from a manifold. If you're going to upgrade the cams as well you might want to look into it, but with a basically stock engine with bolt ons you probably won't get anywhere near what the manufacturer's dyno numbers claim.
