the LS and B20 cranks are the same, dont bother changing one out for the other
boring a stock LS to 84mm is asking to blow up
now if you meant resleeving it to 84mm, then yeah definatly go that route.... a resleeved 84mm LS block will be stronger than a stock B20 block
