would this work
Discussion in 'Civic and CRX - EF' started by 91hatchzc, Aug 19, 2006.
  1. 91hatchzc
    91hatchzc New Member
    if i take a civic long shaft and put a 90-93 integra inter jonit on it would that work if u dont got a Civic ZC intermediate shaft
  2. hybrid_b18
    hybrid_b18 crew chief
    Burnsville, MINNESNOWTA
    Why you making soo many problems for your self. Just get the one that goes for that motor, stop trying to make thing go together that dont. Believe me its easier that way.
  3. coldtotouch
    coldtotouch Junior Member
    Can someone confirm this...
    The obx lsd should solve your problem. Don't believe you need the shafts after that. Infact it can be any LSD (again, if i'm not mistaken)
    i could be wrong...
  4. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    And you are wrong.
    he's talking about axles... not differentials.
  5. jlicrx
    jlicrx Senior Member
    Colorado Springs
    you could put any model stock DX/LX/EX/Si differential carrier and side gears in it (except for the ZC), as long as it had the same size bearings, and then use the stock axles
