wtb: almoust done with swap
mad_hatter
Its Da Mad Hatter
ok my 89 crx dx swap with b18c1 gsr is almoust done so im hoping someone has these parts laying around help me out thanks
gsr stuff
valve cover washers and nuts
valve cover stud inner one for the spark cover
spark plug cover
tps sensor
thermostat housing
91 teg stuff
clutch/throttle/tranny cables
obd1 ecu plugs cut or conversion harness cheap
crx stuff
driver door panel
window track has rubber insert i need the rear one
steering column cover with screws
si floor matts
rear box mounting hardware
driver sd window wiper
rear hatch struts
radiator support
